Teaspoon
- Camden,Tn.
Went to look at a Up Grade job this evening.
The Existing Service is an old 100 amp.
The fuse boxes were in an old cellar there was a combination, of 60 amp fuse
panel,30 amp Disconnect another 60 amp fuseable disconnect
Anyway there was a total of 5 different Boxes in the cellar.
Feeding from one box to the next. with wires double lugged.
connections made by just twisting wires together, no tape no wirenuts.
Black wires used for ground. No covers on any boxes wires hanging out of the boxes .the last panel a 200 amp breaker panel.
installed on the main floor fed by a #6 romex jumped off a 60 amp fuseable disconnect. but only fed with 120 volts . this panel has (6 ) 20 amp circuits in it.Suppling voltage to an addition that was added on a few years ago.
When I first looked at the 200 amp panel I noticed that every other space on the buss bar was empty then after looking closer I saw that the panel was only fed with 120volts Only . No Ground.
Any way I working up a bid for this job. Wish me luck I am going to need it on this job.
