hillbilly1
- North Georgia mountains
- Owner/electrical contractor
steve. in reading this post i got to ask you a guestion. did you remove all the grounds that was on the neutral bus if not you may want to look at article 550.... 550.16- 550.16a,b,c
With mobile homes, they already are separated from the factory, so that should not have been an issue. They have used 4 wire for ranges and dryers long before it was required in houses. Troubleshooted a wood frame, wood sided house that all of the nail heads, propane tank were live. The builder had used foil backed styrofoam as sheathing, He had spliced the stove cable in the attic in a metal octagon j-box that was not grounded, shorting one of the hots to the box. The nail that he had used to fasten the box pierced the foil on the insulation, causing it become live, thus making the nailheads and the copper gas line that run through it hot!
