Aginghiker
New member
- Elizabethtown, KY
Is a fiberglass church baptistry, 42" deep, considered a swimming pool as far as grounding and bonding are concerned?
i do not have a problem with that but generally a baptistery is drained after being used and normally similar to a bath tub they do not have a filter system
either way the manufactures instructions should outline the bonding requirements
I used to do fire protection service at a church with a baptistry and it was always left full. It was pretty large, probably every bit of 200 gallons and then some. If filled for every use, that water would be bone-chilling cold. It could take 3-5 days for the water to reach room temperature. The water bill might be a bit onerous as well.
Only usual requirement for a bath is no switches or receptacles are permitted within the tub/shower space. They can be immediately adjacent to it though. GFCI is required for 15/20 amp receptacles in a bathroom regardless of vicinity to a tub/sink etc. but not for general lighting circuits so a switch could be right next to the tub space with no GFCI protection involved.If it turns out that the baptistery has no electricals and is like a bath tub then 680 wouldn't apply. However, I would think that the usual requirements for a bath would apply like distance from receptacles and switches, lighting, etc.
-Hal
