- Placerville, CA, USA
- Retired PV System Designer
Or that lack of water inhibits it.
Tapatalk!
Tapatalk!
On the contrary, water is a natural solvent and pure water is an extremely aggressive solvent! Ultrapure water is highly corrosive and will attack stainless steel and even glass. This is because water molecules are polar, and without impurities, there is nothing to buffer their action. As the pure, polar water molecules collide with the molecules of the substance it's in contact with, they will rip those other molecules away.Not pure water, which is chemically inert without current flow.
I would have to agree and state that is probably why we don't really find pure water - we have to make it pure.On the contrary, water is a natural solvent and pure water is an extremely aggressive solvent! Ultrapure water is highly corrosive and will attack stainless steel and even glass. This is because water molecules are polar, and without impurities, there is nothing to buffer their action. As the pure, polar water molecules collide with the molecules of the substance it's in contact with, they will rip those other molecules away.
However, pure water is a very good dielectric (182,000 Ohm?m).
This is an interesting thread.
A few weeks ago we were wrapping the rough up on a large custom home on inspection day. The inspector (combo) showed up, walked in the garage and the first thing he said was...... you can't secure the bare copper GEC with steel staples....... he said steel and copper can never touch. He then walked into the house and started looking at other things.
My lead guy walked into the house with the water pipe ground clamp and asked how he was supposed to connect the copper wire to the ground clamp since the clamp has a steel screw. The inspector didn't respond.
I commented to the inspector that steel and copper touch all the time for electrical installations. I mentioned armor ground and ground pigtails to boxes. He didn't want to hear it.
I finally walked out to my truck and found some of the plastic staples with 2-nails and had my guy replace the steel staples. It took him about 5 minutes. Normally I never give in to inspectors but I didn't want to get this guys so pissed off that he takes it out on the builder. He was there to inspect electrical, plumbing, mechanical and framing.
POCO's use steel staples all the time to attach their grounding electrode conductors down the side of wood poles, and they also have the chemicals used to treat the poles to help work against them - yet the only disappearance of copper is usually because of copper thieves:happyyes:.If the staples go into damp wood it might actually be a problem....
But the staple might corrode through before the wire.
Tapatalk!
