ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
If a neutral touches the ECG out at the end of a 120V branch circuit, assuming that the EGC has the same resistance back to the panel as the neutral, it will carry half the current of the circuit.How would there be a lot of current? The path will have a high resistance there there will be very little voltage to drive the current. The only voltage to drive the current is the voltage drop on the grounded conductor, again this assumes that there are no high resistance connections in the grounded conductor.
