jeff43222
- Minneapolis, Minnesota
I have a HO who is finishing most of her basement, and I'm going to be wiring it up for her. I'm not 100% clear on how 210.52(G) should be interpreted. Here's the situation:
The area around the furnace and water heater is being turned into a room/workshop with a large door for access. That room will be unfinished on the inside (no drywall, bare joists above, bare floor). The rest of the basement will have drywall, a drop ceiling will be put in, and vinyl or carpet will be put down on the floor. There will be a separate (finished) laundry room with a door, a small pantry with a door, and a small closet where the plumbing comes in. Otherwise, the remaining space to be finished is irregularly shaped but without any doors dividing it up. Except for the furnace room, laundry room, pantry, and closet, this space is intended to be used as a place for her kids to play and do arts & crafts.
My question regards the part of 210.52(G) that says:
What part of this basement is considered a habitable room? My feeling is that the only habitable part of the basement is the irregularly shaped space, and technically it's really only one "portion" of the basement since there are no clear demarcartions. Can I really get away with installing just one receptacle (in addition to the laundry, of course) for the whole basement because of this?
I'm asking because the HO doesn't really think a lot of receptacles are needed, and she wants to keep expenses down. She's mainly interested in installing a lot of lights in various places.
"Where a portion of the basement is finished into one or more habitable rooms, each separate unfinished portion shall have a receptacle outlet installed in accordance with this section."
