Hi, feel free to laugh if this make me sound simple but here goes..
Firstly I am in the UK but cannot find any forums with any answers so I am here...
I have just commisioned a Hirzt F8 Multibore CNC machine for a friend.
There was an existing isolator outlet and cable run in of 4 core 2.5mm fire rated cable to a 16amp 3 phase breaker within the Distribution panel.
According the the colour code L1 was Brown L2 was Black and L3 was Grey.
I tested this back to the panel to make sure there were no issues with the existing installation and then connected according to the above.With no Neutral but an Earth as the machine does not require the neutral.
The machine fired up and after a bit of fiddling with CNC controls I set it to drill out a 35mm hinge hole in a door. Smoke ensued which indicated the Drill bit was running in reverse. I then Swapped L1 for L2 and tried again with success. I noticed however that on the machines block for wiring, at the top from left to right it says L1, L2, L3 and respectivley below each one it says R, S and T. Now I have not worked much with 3 Phase, but did cover it in the 16th Wiring Regs, (UK Standard for electricians) and have checked the book but can not find a definition for these.
This is my question what do R, S and T stand for in 3 phase terminoligy?
Thankyou for your time
Richie
Richie
