charlie
- Indianapolis
crossman said:. . . the power company linemen . . take no particular pains to provide either a clockwise or counterclockwise rotation to a building . . .
Do your linemen have to keep track of which conductors are "A" phase all the way from the poco generator through the substations through the last xfmr so that "A" is always "A"?
To answer the first question, you are correct. However, we use a phase rotation meter to verify that the rotation is correct if we rebuild or replace a bank of transformers. I assume that other electric utilities have the same practice.
The second question is more complicated. We do indeed keep track of A?, B?, and C? from the substations so that we can balance the loads on the primary phases from the substation (I don't know much about transmission line engineering). Also, we always put the lighter (the one that is center tap connected to the neutral) of an open delta bank on the leading phase. It is not the linemen that do this but the engineers specify the phasing on the work request drawing and specify which transformer goes on which phase. This information is kept on our AM/FM system (automated mapping and facilities mapping). Again, with the advent of AM/FM systems, I assume that other electric utilities have the same practice.
