Alwayslearningelec
- NJ
- Estimator
My issue with said rule is when you have a drive that is rated for more than the motor connected to it. Technically you have to size input conductors to drive input, I have had a few cases where an oversized drive just happened to be available and why not use it. Like a 250 hp drive on a 100 hp motor. Drive is never going to draw anywhere close to it's input rating in this instance, if it does chances are it is also going to have a fault code on it in virtually no time and will shut down anyway.
If a disconnect ws put in the middle of this run how would that be sized? Is that an overload?
