Bath exhaust fans
csw
I live in Va , I had an inspector tell me that I could not use plastic flex to vent a bath exhaust fan.He said that it is code, in the NEC,
for me to use metel flex to vent this fan.I cant find the code,can someone tell me where ,in the NEC 2002 book ,it says that at?
speedypetey
Re: Bath exhaust fans
How on earth could the code book for electrical wiring and installation cove an air duct? This would be my question to him. Aside from; "Um, now which article is that?"
roger
Fl
Retired Electrician
This is a "code" requirement in some locations, but it is not part of the NEC.
Roger
jxofaltrds
Inspector Mike®
Mike P. Columbus Ohio
ESI, PI, RBO
250.80.(g) Other Plastic Piping. Interior plastic piping that may become energized shall be bonded to the service equipment enclosure. The bonding jumper shall be sized in accordance with Table 250.95 using the rating of the circuit that may energize the piping.
Mike P.
jxofaltrds
Inspector Mike®
ESI, PI, RBO
Ryan
This site is designed for:
Contractors
Electricians
Engineers
Inspectors
Instructors
Other electrically related individuals
Mike P. ;)
roger
Fl
Retired Electrician
Mike, in this case the poster is not asking a how to question, he is asking for assistance in an inspectors incorrect statement.
Roger
al hildenbrand
Minnesota
Electrical Contractor, Electrical Consultant, Electrical Engineer
Boy,
I had to look up 250.80(G). Good thing I did. I'd also overlooked 250.80(F) which discusses bonding of skyhooks and 250.80(E) for where to bond snipe.
:D
jxofaltrds
Inspector Mike®
ESI, PI, RBO
Roger
I know. I want him to print this post to show the inspector.
I want him, and I know if he does this it will harm him, show the inspector what an idiot he is?
Roger you are correct to defend others. It was not my intent to attack the poster, rather to show the ignorance of the inspector.
Mike P.
roger
Fl
Retired Electrician
Sorry Mike, I missed your intent? :eek:
BTW, what's the latest on the Bridge investigation?
Roger
d and o
how much are they gettin for them skyhooks up in Minnesota??
oh, and down here, they fail the mechanical permit on any exhaust fan problems. Therefore, I'm now out of the fan business.
We just connect the electric to them, like we do the heat pump/condenser and the air handler.
The AC man provides and installs them as well
earlydean
You folks are mistaken if you think that you only have to satisfy the NEC. Every state and city adopts a building code, which usually has the NEC as a part of the code. Those areas where the NEC is silent is covered by another code. In this case, the Residential Code covers it in the mechanical section. As Ryan noted, the IRC is silent on this issue, which means if the manufacturer's instructions allow plastic, then plastic is OK. The IRC, by the way, requires a minimum 50 cfm unit for intermittent use and 20 cfm unit for continuous use.
roger
Fl
Retired Electrician
Earl, the question had nothing to do with what codes we must adhere to, it was where this issue was located in the NEC, which it isn't.
Roger
luke warmwater
We do only have to satisfy the requirements of NEC as all of our proposals say so.
We work in so many different places that it is impossible for us as an electrical contractor to know every township's special requirements on other than NEC issues. We spell it out in our proposal and it is up to the G.C. to inform us of any such issues.
I do know that 'round here, the plastic flex won't pass. It has to be metal flex and if the exhaust duct goes verticle between floors, that section has to be solid metal duct.
eprice
Utah
luke warmwater,
please understand I'm trying to pick a fight here :) but there are some reasons that I might fail you on an electrical inspection even though the work might be completely NEC compliant, and regardless of what your proposals say. Examples that come to mind are insufficient emergency lighting or exit signage, or smoke detectors not provided in locations that require them. These are covered in the building code. And, to get back to the topic of this thread, improper bathroom exhaust duct material. I'm not aware of a requirement that they be metal, but the IMC in section 603.5 requires flexible ducts to be tested in accordance with UL 181 and to be installed in accordance with the manufacturer's instructions. In my area, it's not always the electrican who installs these ducts, so I would fail whoever installed them :)
luke warmwater
e,
I like fights 'cause I could use a good whoopin'!!
I'm not saying that we don't do such things, but they are taken care of as Change Orders.
The things that you mention are not NEC items, so you could Not fail my ELECTRICAL inspection and win (unless there was an NEC or local ammended Code violation), rather, you would be failing the building inspection.
