Not completely. Imagine all of the energy saved by not running the CFL light in the bathroom an extra 15 minutes just so you could leave the fan running.
A requirement to have separate switch legs running to/from the fan unit would have made even more sense, since it would allow all sorts of independent control without necessarily having to install two manual switches.
In my parent's house near Santa Rosa, built circa 1975, the powder room (guest facility with toilet and sink only) had only a single switch and the fan was very noisy. Since only one run of NM came from the fan and the separate light out to the single gang switch box at the door, I built a small electronic module that plugged between the fan motor unit and the receptacle inside the fan enclosure.
When you turned on the light switch, both light and fan came on, preserving the original functionality. But when you flicked the switch off and back on, the fan was locked out until you left the switch off for more than 5 seconds.
I thought about marketing it, but the Tuit never showed up. :happysad:
