I would not say it is good but it is not an NEC violation.Originally posted by mtn_elec:
when I say behind the sink I mean right in the middle of the sink. It is still good?
How do figure that?Originally posted by jimwalker:
It's ok to let it be there but won't qualify for the required adjacent one.
The first sentence of 210.52(D) statesOriginally posted by jimwalker:
Simple Bob.Read what it says.Adjacent to the basin and within 3 feet
So we know the outlet must be withing 3' of the outside edge of the sink. I can make that measurement in any direction210.52(D) Bathrooms. In dwelling units, at least one wall receptacle outlet shall be installed in bathrooms within 900 mm (3 ft) of the outside edge of each basin.
So by your interpretation would you say the receptacle outlet can not be located above the basin countertop but must be beside the basin countertop?The receptacle outlet shall be located on a wall or partition that is adjacent to the basin or basin countertop.
I agree, that is why it is important to read code sections carefully and not work from memory.Originally posted by ty:
I think that's a simple mis-read.
No, it is you who is guilty of misreading the sentence.Originally posted by ty: I think that's a simple mis-read.
It is the wall that must be adjacent.
Indeed, it's a painful lesson sometimes but true. You must insist on details at the rough or you will pay for it at the trim.Originally posted by jimwalker:
As to the problem ,you are as much to blame as the customer is.
No, look at the definition of adjacent. If the wall across the room isn't connected to the basin in question, then it's not adjacent.If we are going to call the wall behind it adjacent then the one in front is also adjacent.Perhaps they needed to say from the side of the sink.So using this reasoning i will put the outlet on the wall behind me as i stand facing the sink.
I would not call it adjacent but lets say it is, that means to put the outlet on that wall the wall must be within 36" of the sink edge and if it was this close would putting that outlet on it really be a bad idea?Originally posted by jimwalker:
I would call the wall behind the sink BEHIND or TO THE REAR,adjacent is not a good choice but i must agree that while it is behind the sink it also is adjacent.
