K8MHZ
- Electrician
I could also put wall sconces in that space if they where wet location rated.
Now *that* would be cool!
brother said:like i said, if its 'listed for the purpose'.![]()
K8MHZ said:How about a chandelier in the shower?
You wouldnt really put a line voltage sconce in a tub/shower enclosure would you??? edit to change light to sconce oopsiwire said:I can place a light fixture in the same place that the fan is, or I could replace it with a fan light
quogueelectric said:You wouldnt really put a line voltage sconce in a tub/shower enclosure would you??? edit to change light to sconce oops
480sparky said:So where is the light that is causing the shadow?
K8MHZ said:Maybe it's one of Bob's sconce lights.
BTW, what you see in the picture *is* code compliant!
iwire said:....It looks like a hanging fixture in a shower stall, what are we missing?
480sparky said:It looks like
do you own a megger?dSilanskas said:Hey guys I just came from a friend of the familys house. They told me that there bathfan that they had installed about three years ago keeps popping the breaker. Went by and saw they had a fan installed in the shower itself haha. Well the shower is all glass doors with only a little opening above the door. I know that it was tripping the GFCI breaker because of the steam getting into the fan and building up water. I have never seen a fan installed in a shower like this before dont know if its legal to be honest with you. But I didn't know if any of you guys have any ideas for a replacement fan if such a thing is made? Here is what it looks like and thank you for your help as always :smile:
http://i195.photobucket.com/albums/z250/dSilanskas/Bathfan.jpg
Even in 14 wire??That is just sooo wrong! However Bob had a good point that they make nice soap holders. :grin:stickboy1375 said:Yes, without gfi protection as well...
quogueelectric said:Even in 14 wire??That is just sooo wrong! However Bob had a good point that they make nice soap holders. :grin:
i think if a light is listed to be in a wet location then it can be located inside of a shower GFCI protection or not. personally i would put it on a gfci. if the instructions to say to put it on a gfci and you dont then you are going against its UL listing and against 110.3B. thats why we can put bath fans in showers just as long they are on a GFCI since its part of its listingquogueelectric said:Even in 14 wire??That is just sooo wrong! However Bob had a good point that they make nice soap holders. :grin:
iwire said:And they make great soap holders.... :grin:
Please go on..
Would you put one in your mothers tub??stickboy1375 said:But so legal...So I guess its your opinion vs the NEC. :roll:
quogueelectric said:Would you put one in your mothers tub??
