1793
- Louisville, Kentucky
- Inspector
Does a convenience receptacle in the bathroom of a SFD have to be on the dedicated bathroom circuit?
Thanks.
Thanks.
What is a convenience receptacle?
Not exactly. You can have more than one bath receptacle circuit.you are required to have one circuit for the bathroom receptacle outlet(s) as the code reads "outlet(s) " I see it requireing all bath receptacle oulets to be on this circuit
In a nutshell, the rules are:
If anything other than a bath's receptacle(s) is supplied, then the circuit cannot supply anything outside that bathroom.
If more than one bath's receptacles are supplied by a circuit, then only bath receptacles may be supplied.
aka "general purpose" recep
Sorry if I'm showing my age with "old" terminology. There are two receptacles serving the sink / vanity area. The bathroom is quite large and the customer wants an outlet installed on the other side of the bathroom.
It will be GFI protected for sure but I was looking into options of where I could get the feed. There is a closet, with some outlets, just off the bathroom I was planning on using. I'm not sure if the outlets in the closet are on the 20a bathroom circuit.
If not could I still use it without creating a violation?
Of course.Am I thinking correctly that a receptacle outlet in a bathroom cannot be on the living room circuit?
Because it's for all bath receptacles, not just required bath receptacles.I'm having trouble seeing where if the required outlets are supplied and not used for anything else the why can't another circuit supply receptacle outlets other than those that are required, away from the sink.
Same as for kitchen countertop receptacles.
What is crazy is that this would been fine about 15 years ago but now is a hazard. Hazard of what i do not know.I can live with that. Just thinking out loud.
