splinetto said:Always wondered if it would be OK to put a duplex in the middle of a double bowl vanity and meet the requirment of 210.52?
splinetto said:Always wondered if it would be OK to put one duplex in the middle of a double bowl vanity and meet the requirment of 210.52?
C3PO said:Sure as long as the receptacle is within 3 ft of the outside edge of both basins
Great Scott! A flat out yes or no answer!electricmanscott said:Splinetto, Please, Ignore the technical mumbo jumo that this thread is heading towards. One receptacle is fine and allowed.
infinity said:How do you define outside edge when the two basins are next to each other?
My answer is that a basin has two outside edges, one to the left and one to the right. (I am, of course, only looking in two dimensions, but I think the code is too.) So if you have two basins side by side, and each is 3.5 feet wide, and there is one foot between them, and if you put a receptacle in the wall between them, then that receptacle will be within 3 feet of the right-hand outer edge of the basin on the left, and it will be within 3 feet of the left-hand outer edge of the basin on the right.iwire said:I am not following you on this, the outside edge is the outside edge.
