Bathroom panel
dm9289
Industrial Maintenance Electrician
Pennsylvania
Industrial process repair/ maintenance Electrician
Would an existing panel be code compliant in a bathroom if the door opens on the outside of the bathroom?
Sounds like a gray area on a residential bathroom. It must be pretty close to outside the bath. Do you have a pic?
You know, It's okay in commercial not residential
There's a lot better way of stating this than "door opens toward another room", that's confusing. Just say it's in a xx room wall that shares a wall with the bathroom. Sharing a wall is not the same as being in a room. You could say a panel is outside but door opens to the inside, doesn't make sense.
The panel is not in the bathroom.
Panel door would open into another room
Yea I prefer how you stated it better. Yes a shared wall
The description is that there is a panel in a bathroom, but its door opens outside the bathroom.
Thus, I conclude that the back of the panel is toward the bathroom, so it's in the bathroom wall.
Correct shared partition wall back of panel towards bathroom but covered with dry wall
Semantics…
Then the panel is not in the bathroom. It is in a wall that forms a bathroom wall, but that’s not the same as being in the bathroom.
No problem being in a wall that backs up to a bathroom. I’ve done it a couple of times where they have converted a laundry room next to a garage into another bathroom, and the breaker panel was already on the other side of the (now) bathroom wall in the garage. Both passed planning and inspections.
Looked to me that he said the panel is in the bathroom, but the panel door opens outside the bathroom.
I would interpret that to mean the panel is inside the bathroom, immediately next to bathroom entrance, and that when the panel door is opened it's in a different room than the panel 🤷‍♂️🤷‍♂️
But he's clarified that it's not inside the bathroom, just in the wall separating the bathroom from the other space
