Battery Cable Cutter
Dansos
PA
In the market for a Battery operates cable cutter. Working with a lot of 250 and 500 MCM and 200 amp SER. Wanted to get the Milwaukee 12v bc that’s all I really use so I have a stock of batteries, also it is the cheapest. Anyone have any feedback on the Milwaukee or does anyone use a different brand?
I’ve had the 12 Volt Milwaukee for about a year now and it has not failed me yet. Only think that chipped my blades was when my helper cut a piece is steel from the power company ties.
Definitely recommended
Ron
If you already use Milwaukee batteries for other tools - seems the most logical way to go.
My battery cable cutter is a Milwaukee Hackzall;)
We have the Milwaukee M18, its an impressive tool as it will cut 1/2" rebar.
Electricians (3) and myself (instrument tech) have mostly Milwaukee. I am 100% Milwaukee at home and work even have one of the M18 heat guns
i've got a burndy and a milwualkee, so i'm doubled up,
and only need one..... the 12 volt works ok, on 500 MCM
copper it'll twist a small amount as it cuts. just the nature
of the tool.
they are about $320~$350 new. $100 gets this one, if you
are in the market for a used one.
Am I the only one who, when seeing the title of this thread, thought he was seeking advice on equipment used to steal car batteries?
of the tool.
Do you have a12 volt Milwaukee for $100.
Thanks
