mgookin
- Fort Myers, FL
- Retired inspector, plans examiner & building official
Just wait one year and buy batteries then.
We use 12V, 120 to 180AH low maintenance lead acid battery for generators. For some cell tower sites, the generator is supplied prior to obtaining POCO supply. So the battery sits idle along with the generator some times more than a year. When time finally comes for commissioning the tower, it used to see the battery dead beyond revival and the supplier stated only one year warranty. But the battery shelf life now a days is two years. Your opinion please.
OP is in India, don't know if that situation is common there or not.If this is a remote cell site or even in a urban area you would not have to worry about the generator. In a years time someone will take it and use it somewhere unknown to you.
Cell sites are target #1 for crack heads. They take everything that is not bolted down. In DFW area alone Verizon Wireless has on average 4 to 5 cells sites a week hit with copper thieves.
I was going to suggest that, seems as though everyone in the last few posts agrees with that concept to some extent.Just wait one year and buy batteries then.
If that is the case then I would certainly would not let a genset set in a crate or installed outside in a tropical environment without running once a week. I would put it in dry storage and install when needed.OP is in India, don't know if that situation is common there or not.
Not possible once lead sulfate crystals have hardened. They can only be dissolved while they are in the soft gel stage. After that it is over.Sometimes the battery may be revived by very slow charging to reverse the sulphation process already set in in the idle lying battery.
Could be useful here............What about the magical devices that use high frequency pulses to vibrate the crystals into submission? I understand they also repel gophers and mosquitoes.![]()
I have more interest in the repelling action than I have in reviving a battery at this time, the gophers raised hell with my yard last year, and one of these years the mosquitoes will probably return, last two or three years have been dry enough they weren't a widespread problem like they sometimes are.What about the magical devices that use high frequency pulses to vibrate the crystals into submission? I understand they also repel gophers and mosquitoes.
Tapatalk!
