ronaldsax said:I'm working in a remodeling , the house is next to the beach and I found that everything is EMT and THHN , is there any reason in the code to use EMT with THHN for a beach house , or I can simply use NM ?
thank you very much
ronaldsax said:If I want to find this out, where should I go ? do I need to talk to the inspector? or who can tell me the local regulations?? thanks
ronaldsax said:I'm in north West Palm Beach , Florida
dezwitinc said:We just finished working on a condo down on Deerfield Beach.
It had been wired 20 odd years ago with EMT.
The first time I poked my head up in the attic, I was dumfounded to see THHN laying all over the ceiling and hanging from the joists.
Due to the salt air circulating through the attic, the EMT had turned to dust and some junction boxes were rotted beyond recognition.
I would vote for as much nonmetallic material as you could fit in that place.
kbsparky said:I would NOT recomment using any metal conduit system anywhere near a salt-water beach. We use PVC conduit, or NM cabling in such areas. As much plastic boxes as you can get.
