I am primarily a residential electrician, but I have a customer who wants his large shop wired up with 30 LED strips( http://www.mobern.com/Specifications/44LEDseries.pdf ). He also wants them dimmable. I have no experience with this and haven't found a good resource for learning more about it. These strips are 57watts, 6400 lumens, and 0-10v driver. On a 20 amp circuit I should be able to run all fixtures together. My question is in the dimming. Can all these be dimmed together with one switch? And am I simply running a 3-wire low voltage line together with my nm wire, jumping in and out of each fixture? Any help is appreciated.
