Beginner LED dimming help
ram11379
I am primarily a residential electrician, but I have a customer who wants his large shop wired up with 30 LED strips( http://www.mobern.com/Specifications/44LEDseries.pdf ). He also wants them dimmable. I have no experience with this and haven't found a good resource for learning more about it. These strips are 57watts, 6400 lumens, and 0-10v driver. On a 20 amp circuit I should be able to run all fixtures together. My question is in the dimming. Can all these be dimmed together with one switch? And am I simply running a 3-wire low voltage line together with my nm wire, jumping in and out of each fixture? Any help is appreciated.
I did contact Lutron, and from what they described to avoid having to have a lighting panel and everything I could simply use 3 DVSTV switches(one per row) and that should be sufficient. I still am not positive about the actual wiring as I do not have the lights yet to look at. But it does look like I will just be running a 18/3 wire along with my nm. One in and one out of each fixture.
Edit... I meant 18/4. It seems I only need 2 wires for switch, but I have 18/4 tstat wire already. I guess I'm asking is that sufficient or do I need stranded, shielded, etc? There will be nothing else running on the ceiling but these lights and the runs will be no longer then 120'.
