hurk27
- Portage, Indiana NEC: 2008
I haven't seen anything in writing that it is guaranteed but this is why they are doing this test and recording the KW with a meter. This unit was a free-bee to change over in hopes they can prove the change will save money.
Yes we would have seen an increase in KW but the funniest part is there is a chance the fan would not have lasted long at 2200 RMP. She was a screaming when it was first started.
I already see one problem, the fact that the mechanical ratio between the motor and fan has changed, this will affect start up of motor as well as any ability of running it in bypass mode if ever needed in case of drive failure, they should have been better at making sure the ratio between the motor and fan was not changed, if they had any understanding of what it would cause this should have been part of their design, who are these guys??? sounds sloppy to me, in any constant torque application RMPs of the load can make a big difference as well as start up load on the motor if the ratio is less then what it was to start with?
