An issue came up today at site where we cant install ground rods vertically due to rock and other under ground obstructions.
Seems the only solution is to install the ground rods horizontally 30" deep.
My question is does the code allow the ground rods to be "bent" by 90 degrees so that they can fit into the test well via bottom entry?
The length of the rods will still have 8ft of horizontal contact to earth.
Thanks
Thanks
