Best anchors for conduit trapeze hanger on concrete
MAC702
Clark County, NV
Wedge anchors
sameguy
New York
Master Elec./JW retired
I try to get them in before the pour. Drill the Q deck and drop rods down.
Drop in anchors mostly.
Make sure you have the right bit for the Hiltis
blakrew
Fort Lauderdale
Foreman
I use these nVent Caddy 4TIB Rod & Wire Angle Bracket, For 1/4" Threaded Rod, Steel after the pour if I cant get in before. They are quick and easy and rated 100lbs
Eddie702
Licensed Electrician
Western Massachusetts
@infinity
Question on the anchors in the picture. Do they come with the rod coupling? The sleeve anchors I have seen the threaded stud is smaller than the drilled hole=3/8" hole 5/16" threaded and 1/2" hole 3/8" threaded or do they use Increaser/reducer rod couplings?
brantmacga
Señor Member
Georgia
Former Child
@infinity
Yes, the coupling is the nut that drives the wedge anchor in place.
infinity
New Jersey
Journeyman Electrician
@infinity
Yes the actual stud part of the anchor is one size smaller than the rod hanger size so a 1/2" anchor has a 1/2" thread for the rod and a 3/8 thread that connects to the stud on the anchor. It comes as one piece as shown with the rod coupling. For years we used drop in anchors but IMO these are better. The drop in's require a hole larger than the anchor size so you're drilling more concrete every time. Also drop in's (especially the larger ones) require quite a bit of hammering with the setting tool to set them in the concrete. These anchor get tapped in lightly with a hammer and set with a ratchet, box wrench or what I use an impact driver.
gadfly56
New Jersey
Professional Engineer, Fire & Life Safety
It probably doesn't matter for most work folks here do, but pay very close attention to the specifications on large projects. At the terminal expansion for LGA there are some serious restrictions on what types of hangers can be used. IIRCC, you can't use cartridge activated devices to shoot anchors overhead, and there are other restrictions as to where on the waffle slab you can make a connection.
Alwayslearningelec
NJ
Estimator
So if you were handing threaded rod you could use a sleeve or edge anchor with a rod coupling instead of rod anchor?? Understand seems like rod anchor would be more practical install.
