mbrooke
Batteries Included
- United States
- Technician
What is your favorite? What is the best? Raco-Hubell? Halex? Arlington? Steal-City?
Steel, the brand doesn't really matter.
Roger
What if the connector says "zinc"
IS that just the coating or the whole thing is zinc?
What do you think?
All zinc is a die cast zinc fitting. They break off easier than a steel fitting does.
Best die cast zinc fittings used to be "Regal" fittings, but they are no longer around. I switched to using steel fittings when they disappeared, they all seem to be about the same, gets to the point you have to wonder if they aren't all made at the same place anyway.
Haven't found a "raintight fitting" I like yet, they all stink.
Thomas and Betts, steel, set screw. If you want first class get the ones with nylon inserts (built in bushing)
