4x4dually
- Stillwater, OK
- Electrical Engineer/ Ex-Electrician
As some have seen me post, my friends property burned a while back in the wildfires we had in OK. The well house guys are coming next week to set a new one and I need to feed a 30A service out to it. Seeing how everything before was ran in PVC....thus....burned to complete hell....is there an option that's better? I could run EMT but it's not good for underground and required DB fittings and wrap. I don't have a threader to run rigid. Would it be feasible and/or permissible to run PVC underground and transition to EMT right at ground level using a female pvc adapter and using compression EMT fittings?
Any advice would be much appreciated.
Pics for reference. I also have to come up with a new feed-thru type breaker panel like this. Pole feeds the panel, house is fed-thru, and breakers to cut in barn and pump house feed. I've never seen a panel like this before....not that I claim to have seen it all, but it kinda was like...wow, look at that.
