tx2step
- North Texas, DFW area
I've mainly done commercial and industrial work before, but am starting to do some residential now, too. A few days ago I was replacing a ceiling light fixture with a ceiling fan. This was on the first floor of a 2 story house, so no access from above - only from below. It was a textured sheetrock ceiling. The existing ceiling box was a 4" round brown plastic box (with only 8-32 screws) that was nailed to the ceiling joist with 2 nails outside the box (the standard type, with the molded supports/nails outside the box at about 45 deg. to the box). I had a hard time getting the existing box out of the ceiling from below -- I finally clipped the box apart using my diagonal cutters (dikes) a piece at a time until I could get to the nails. There must be an easier way!!! How do you guys do it??? I'm sure I'll run into this situation a lot, and I want to make a much easier job of it in the future!!!
After I finally got the existing box out, I installed (from below) one of the steel fan boxes (with 10-32 screws) with the screw-out type bar hanger that extends to "bite" into the wood joists on each side. It seemed pretty solid. I think it was a Steel City model, but I'm not sure about that. Is there something better and easier to use?
Thanks for the help!!!
