MAK
- Massachusetts-Boston
Ahh ok, if I was going to get an Ideal, it would be the Racheting Telemaster:
http://cgi.ebay.com/New-Ideal-30-69...rimp-Tool-/290409285630?pt=LH_DefaultDomain_0
It's half the price of the Paladin
But is the Paladin twice the quality of the Racheting Ideal, or is the Ideal Rachteting Telemaster a really good crimper?
Also, Wireguru mentioned that the "ends for Paladins are expensive" - does that mean that you have to use proprietary Paladin connectors?
I'm looking for more of a "universal" crimper...
So I may just lean towards the Ideal for sure that way.
I think the Ideal does both solid & stranded wire doesnt it?
Thanks.
I think you are going to end up having a couple of those tools eventually so I would not be overly concerned with which one Paladin or Ideal. I use both with just about any 8 pin modular connector I have available.
$25. for the Ideal is a great price so I would not have any problem picking it up for that price.
The "ends" that Wireguru was talking about are for the Platinum tool. If I read correctly that tool uses modular plugs that allow you to pull the conductors out of the end of the plug and then cut them flush with the face of the connector. I think AMP makes a similar version. Some people have an easier time with that version than the more conventional version modular plug.
As far as whether the Ideal tool will do stranded and solid modular plug terminations I am not sure. It would stand to reason that it could because the exterior dimensions of the plug would not change but the hole size in the plug maybe bigger to accommodate the larger area of the stranded cable.
Maybe Wireguru or another member could chime in on that subject.
