GerryB
- woodbridge, ct. USA
I have to get a circuit for an automatic gate at this condo now apartments. It is an L shaped building, 9 units, 6 then 3. The house panel is on the outside next to the meter bank, which is of course the absolute furthest point away from the driveway. If I pipe it outside I would pipe around the corner, then over each garage door and under porches, around a jog(2 extra 90's and an lb), then another corner to get to the gate location. 200 feet, about 4 lb's and 5 90's. I was going to use 3/4 and #10 wire for voltage drop and they want a light on the side of the building. I'm thinking it will be pretty unsightly, pvc might sag, ridgid is harder but I could probably span the jog I mentioned (about 3 feet, make a nice chin up bar), and I don't know about emt and comp couplings. The other choice is to go through each unit. There is some kind of chase because they ran ser to each unit to the panels. Each unit has a garage that I would have to open up sheet rock and find my way. I suppose this is better. Any problems code wise with this? Thanks
