I keep it on the truck right next to the PVC glue
It fits in the palm of your hand. Surely you have a place for something that small?brantmacga said:when you say "truck", you mean 18-wheeler right? if not, how do you fit all of these gadgets into one vehicle???![]()
mdshunk said:It fits in the palm of your hand. Surely you have a place for something that small?
Depends. Sometimes I do. I don't really use "string" myself. I use the poly white/blue stripe stuff, which is darned nice for lighter pulls. Naturally, you'd pull in a rope with the string for the heavier stuff. I've seen ropes saw through ells before too. This is one reason some people use RMC ells in their tougher underground runs of PVC. It helps on tough runs to pull a lube spreader through first.bugzapper said:I've seen several posts that mention a 100' max for fish tape and jet string for over. Nobody mentions another step after sucking the string. Are you using the string to pull the wire?
I think the hand crank tuggers still use steel wire rope.infinity said:Back in the old days it was common to use cable tuggers that had steel rope. Long pulls would cut right through an aluminum elbow if it was near the end that had the tugger.
mdshunk said:I think the hand crank tuggers still use steel wire rope.
TOOL_5150 said:I use the Ridgid reamer below for PVC. It works allright. I call it the monkey barrel.
~Matt
hillbilly said:I didn't know that there was such a tool as a "RIGID REAMER".
