We just did a Best Buy in Ohio and was turned down by inspector for use AMP ENERGY WIRRING . This is what All best buy stores spec this one was my 6th store and we lost over 50 thousand because of the inspector would not allow even thou county stamped drawings
:-? What in the world are you talking about? Please enlighten me
I'm with the Wizard, what is Amp Energy Wiring?
It is kind of like an electroconnect whip system. Factory flex whips with male/female plug and play connectors. Each having A,B or C phase adaption.
I did a turn around at one store where shelf "fixtures" were relocated from one spot to another. The flexible wire means needed to be rerouted as well, if the existing was not long enough a barrell of flex whips was available in the back service bay. Cheesey stuf.
There are a number of local codes that delete Article 604 from the code.
Yes, it should have been caught on plan review, however if it was not clear on the prints and buried in the specs it could have been missed. Just having the drawings stamped on plan review does not relieve the requirement to comply with the code rules, even in cases like this.If that is the case it really should have been brought up during plan review.
Well we got the wirring approved through county office but inspector said he had final say so. - Amp Energy is a form of relock Best Buys has 4 cks that goes to all of there fixtures also the recpts are prefabed and the amp wirring plugs into them. This is Best Buy can move fixtures with ease
