ptonsparky
Tom
- EC - retired
I just did a billed vs unbillable hours and found that almost half of my time as owner is unbillable and 25% of employees time is unbillable. Is this in a normal range?
macmikeman said:Residential service techs average 4 billable hours a day due to driving, set up and so forth. So there is a need to charge more to offset that factor when billing out. For new construction and remodel work commercial or residential the factor will go up to around 7 hrs of productive time per man per day so charging with that in mind when bidding is also recommended.
satcom said:Our residential, commercial service electricians will AVERAGE 4 billable hours a day
growler said:Here is a good article on billable hours. He even talks about how to handle the dreaded refund.
http://ecmweb.com/ar/service_secrets?
How do you assure work doesn't exceed the estimated time? What happens if the job you quoted, expecting it to take 4 hours, ends up taking 8 hours?satcom said:. . . with residential, commercial, service work we use a contract price to assure a profit.
LarryFine said:How do you assure work doesn't exceed the estimated time? What happens if the job you quoted, expecting it to take 4 hours, ends up taking 8 hours?
The reason is that the person doing the estimating, and the people doing the work, often aren't the same.
A lot of old work falls under this category. I often have no idea what I will find until I open things up. I used to quote fixed prices, but I got burned too many times by surprises lurking behind the walls and ceilings. Let's not forget all the wasted time dealing with homeowner GCs who schedule me to trim out their basement, only for me to show up and find the tape-and-mud crew doing their thing.emahler said:and if you have no idea how long it should take, you should be working for someone else.
jeff43222 said:A lot of old work falls under this category. I often have no idea what I will find until I open things up. I used to quote fixed prices, but I got burned too many times by surprises lurking behind the walls and ceilings. Let's not forget all the wasted time dealing with homeowner GCs who schedule me to trim out their basement, only for me to show up and find the tape-and-mud crew doing their thing.
Now I only do upfront pricing when I know for sure that there will be few or no surprises. I'll quote a fixed price for a panel swap or service upgrade, but for most of the other work I do (remodel and repair), I go with T&M. As a result, my EC business is now making decent money for the time I put into it.
