elechank
- lake villa
Got a customer that complains about having to change the par 30 floods in their track lighting system way too much. I think they're using cheap bulbs, any one with ideas?
Hank
Hank
elechank said:Got a customer that complains about having to change the par 30 floods in their track lighting system way too much. I think they're using cheap bulbs, any one with ideas?
Hank
elechank said:I think they're using cheap bulbs, any one with ideas?
Hank
growler said:This is probably not your problem but it's a funny story. I went to a new home because the homeowner complained of bulbs going out. I checked voltage and couple of fixtures then when I didn't see a problem I asked the homeoowner where he buys his lamps.
Buy them, he didn't buy the lamps he was bringing them home from work after a maintenance company changed them out. They were still working and the homeowner didn't want to waste them. It Happens![]()
Incandescent bulbs usually give up the ghost at turn-on, due to cold-filament inrush current. All-day burning probably allows the greatest number of hours of life.Dennis Alwon said:I would almost guarantee the problem is the bulbs unless they are leaving the lights on all day long.
I agree as this might be a possiblity that wouldn't get thought of normally.Sass5150 said:Vibration may be the culprit. I have seen this before. Does the HO have kids...is there a second floor above these lights where they can run aruond slam doors etc.? Try a halogen lamp.
In that case, that settles it. They have a problem.elechank said:Thanks for the help, the heads are closed and I'm told that the bulbs mostly fry out when they're turned on.
Hank
Sounds like it could well be a combination of excessive heat and vibration. Compare the bulb wattage to the fixture label.elechank said:Thanks for the help, the heads are closed and I'm told that the bulbs mostly fry out when they're turned on.
Thank goodness you're here! :wink:mdshunk said:In that case, that settles it. They have a problem.![]()
LarryFine said:Incandescent bulbs usually give up the ghost at turn-on, due to cold-filament inrush current. All-day burning probably allows the greatest number of hours of life.
