- Windsor, CO NEC: 2023
- Hospital Master Electrician
If you look at the instructions for the fixtures, more than half of them require installation to a outlet box mounted to the structure. You should begin requiring specs on the intended fixtures before rough-in, or they can pay for the re-foam and drywall/paint repairs when they decide to make up their minds.frogneck77 said:...we ran into a couple problems.(1) Wires are nearly impossible to snake after the fact-In bathrooms we typically leave a large loop above the vanity location with no rough in box-This allows the HO to decide on # of sconces and fixture placement based on mirror size/decorations on the finish stage of the project. With this insulaton my method didnt work too well.
I used to do the same thing before I realized the code violation - 110.3(B) for the luminaire.
Sure - use normal electrical boxes for the devices instead of open LV rings. You can go for metallic 4 squares and conduit if future expansion is desired.(2) The LV rings for all cable/data/phone locations were full of this insulation making the jacks difficult to install without chipping out alot.
