jmellc
- Durham, NC
- Facility Maintenance Tech. Licensed Electrician
I never cared for the blue Carlon cut in boxes sold at Big Blue and Big Orange. The entry slots crowd the wire in and the clamps often tear loose from the box as it is being installed. Have only used them in a pinch. But I tried 1 version the other day in a mobile home with shallow walls. I used the ones with a funky little side pocket. It has better entry slots too, closer to those on the Slater boxes at supply houses. I found these fit well in the shallow walls. Still had to work harder on the clamps but I will keep a few of these on the truck now. I haven't seen any version of this by Slater, nor have I seen a shallower standard box by Slater. Shallow metal boxes mean jiffy clips which often try to tear out of thin drywall. I have seen 1 other Carlon box that may be nice; a nail up box on a bracket. Has set screws, allowing it to slide forward or back. Would be good if exact thickness of wall is not yet known. Or could turn them out an inch to keep the drywaller from burying the box. I've had jobs where they buried several boxes and can lights.
