jb3551
- Dahlonega, Ga.
- Inspector
I often get called to test boat dock electrical systems which includes the shore side disconnect and the switches and receptacles on the dock. As well as making sure GFCI's are working properly and check for grounding and bonding. I also measure for current in the water. As I listen to one of your videos dealing with the AEMC model 565 for measuring current in water using milliamps I have a question.
Previously I have been checking for electrical current around boat docks by using a regular multimeter and by dropping the negative lead into the water and checking the ground in the receptacle. I would pick up 0.2 amps or a little more at times. But you had mentioned about measuring in milliamps. With the AEMC 565 you recommended, what's the process for using that meter in measuring milliamps? That's one thing you never discussed in your video was how to measure electrical current in water.
