Re: Bolted fault current
Thanks.
So, with regard to arc flash calculations of a machine in a facility, one would then need to know some of the specifics about the supply conductors, OCPD, transformers, etc., in order to determine how quickly the system will deteriorate and at what current level, correct?
Pursuant to NEC 110.16 we have been placing an arc flash warning label on our machinery enclosures. 110.16 only specifies that a warning label is used but does not seem to specify what information in particular is required on the label (not that I have found anyway). Unfortunately I don't have access to a copy of the NFPA 70E code. Is there a reference there that spells this out? Admittedly, we have not included any specifics. Now, some of our customers are requiring or requesting that we include some of the calculated data such as Flash Hazard Boundaries, Incident Energy Level, PPE level, etc. on the warning label. Without knowing specific details about the supply circuit to our equipment, I don?t fully understand how we could provide that level of detail or am I misunderstanding something?
Bob
