Bond Gas Line
Woolfy84
New member
Strip mall restaurant : Can you bond gas line to restaurant sub-panel or have to go back to the service panel ?
Absolutely cannot ground the gas line, very dangerous and against code
TJ, this is not true. It is true that the gas company does not want their lines grounded or used as an electrode however they usually have a dielectric fitting at the meter. The code req. all piping to be bonded- read 250.104(B) as stated above. The egc can be used as the bond for the gas line.
If it is CSST tubing then a #6 or larger is needed back to the service panel.
