Clodbuster
- Eastern Washington
I'm doing an upgrade to a wellpit and am having trouble finding code references (2014) for where the main bond can occur. I would like to do it at the main lug panel in the pit and use the well casing for the grounding electrode, as it will be the easiest and most effective electrode.
The existing system complicates things as it has 2 fused disconnects in series before the (new) main lug panel. The first is immediately after the meter, but is on an intermediate pole 75+ feet from the pit. The second is at a replacement pole about 20 ft from the pit, where the power goes underground and enters the pit via PVC conduit and then the main lug panel. See the sketch below:
Can I make the bond at the main lug panel? And then just run an EGC from the service disconnect (2nd disco) back to it to provide ground continuity?
Secondly, are there any code requirements for grounding electrodes at the first disco?
