macmikeman
- Planet macmikeman
When I'm making up quad covers (2 duplex in a raised Industrial cover) triple pig tails really save time.
A lot of electricians feel #12 pig tails are good for #10![]()
Define good.
When I'm looking at old work or following other electricians finishing things up I notice #12 pigtails on 30A circuits often, so I assume they're either "good" with it or oblivious of the issue.
If we are talking 15/20 amp receptacles, they almost always will be required to be on 15 or 20 amp overcurrent devices. I suppose technically if you ran #10 to the receptacle for the normal current carrying conductors because of voltage drop you would need a #10 grounding wire. If you spliced the #10 and pigtailed #12 to the receptacle then the #12 grounding pigtail is correct.When I'm making up quad covers (2 duplex in a raised Industrial cover) triple pig tails really save time.
