I have a panel in the basement. One gec goes from neutral to ground rod at panel (under panel in basement floor). Another gec goes from neutral to water pipe then ground rod in basement.
I will be installing a antenna. Should I install another rod on the "exterior" of the building, connect it to the neutral with #6, then run #10 to antenna and #10 to (the coaxial) Antenna discharge unit?
OR can I install a IBT from the basement to the exterior and bring the bonds to it?
I'm reading the Antenna discharge unit can be bonded inside or outside the building, but I'm concerned about bonding it inside the building... which I would be doing if I bonded to the intersystem bonding terminal.
True if I put a rod outside, it would still get bonded inside, but I would think any strike would go to earth outside then, rather than back indoors ??
Thank you
Thank you
