hill900505
- Texas
I have a concrete equipment pad encircled by a 4/0 AWG ground ring. There are (2) 3" steel pipes and unistruts built to support 3 electrical panels. Do I need to ground this supporting structure (the 3" pipes or unistruts)? If so, should I run an EGC to a ground bus bar in any of the three panels or should I run a grounding electrode conductor to the ground ring directly? Thanks very much for the help!
