justanotherone
- Vermont
- Property Inspector
Hi I am a property inspector and run into this on going debate with several properties here in VT. The issue is when there is a meter with a service disconnect located on the exterior (not too common around here). My understanding is that at this location, no matter where it is (on a pole 100 yards away from the house or on the side of the house) a driven rod is needed and the neutral and ground shall be bonded in the main service disconnect. Any panel located downstream from this location needs to have 4 wires brought to it and all neutral and grounds need to be separated. I have met a few electricians who claim that if there are ground rods driven in at the remote panel (sub panel) then a fourth wire does not need to be brought from the main service disconnect location. Is this correct? Most recently a licensed electrician is claiming that at 2004, this was allowed and can remain as is. TIA
