FrancisDoody
- Durham, CT
I am installing a #2 aerial feeder to serve a pond aerator. This feeder will terminate into a GE raintight load center. There will be no EGC with the feeder. So in this case I guess you should drive a set of grounding rods and tie the equipment grounding (bonding) conductor into the grounded (neutral) conductor at the load center. This installation should be able to handle the maximum unbalanced load on the neutral and eliminate any parallel neutral current paths back to the power supply source.
Thanks,
Fran
Thanks,
Fran
