jamesjacco
- ormond beach fl.
- electrician
OK I have always bonded gas for residential at the entrance point. Then I also bond with the size wire for the circuit that is also servicing the equipment at the back side of the gas shut off valve. also should be noted that the gas lines, once inside these houses, is csst flexible stainless steel piping. first time ever I had an inspector tell me I need to run a # 10 wire from each piece of equipment back to the panel. some runs are at least 100 to 150 feet. please let me know what you think. I have researched everywhere and the only thing about bonding these csst pipe is there is an investigation going on due to csst having small leaks ( holes ) possibly from near by lightning strikes. everything I have read is vague except for bonding the rigid gas lines. as far as residential there is very little literature ( that I can find ) on this subject. thank you
