That is correct. As Al and Pierre have already said the EGC within the branch circuit is all that you'll need. No further bonding is required.Originally posted by rickl:
thanks
so i don't have to run a bonding jumper from where the egc is made up in the unit to the pipe.
al the 60 amp circuit is for a 5 ton furnace-heat pump combo unit
Oh, your right. Sorry, I should have said Scott and Pierre. Was kind of early this morning.Originally posted by al hildenbrand:
Actually that was "New Scott" and Pierre. I was just wondering about the nature of a 60A gas fired furnace, life, the universe and everything.
Rickl stating there is also heat pump load brings balance and order to my cosmos.
