xguard
- Baton Rouge, LA
This is a snip from a utility company's specifications. I thought 250.80 required the grounded conductor to be bonded to the CT Enclosure. Only a bonding screw is shown for connection to a ground rod. So question 1 is: Shouldn't the CT enclosure be connected to the grounded conductor?
Question 2: In our case we have splices inside the junction box shown in dashed lines. I believe this box also needs to be bonded to the grounded conductor. Assuming all conduits are metal, all bushings are bonding type; does the grounded conductor need to be connected in the Junction Box and in the CT Enclosure or can it just be done in one?
