We have a 1200A 3p 4w 208V service supplied with 3 sets of 600MCM copper. The weatherheads and conduits are threaded rigid conduit. The run is less than 25' to main disconnect. The service GEC is 3/0 copper connected to 3 rods and a water pipe -- no building steel. The GEC is terminated in the 1200A fused main disconnect & bonded to the neutral.
We leave the main disconnect with 4 each 3.5" PVC parallel conduits. Each conduit has 4ea 500MCM Al plus a 3/0AL EGC. This is supplying a remote steel trough for future disconnects by the tenant's contractor. The 3/0 AL EGC's are bonded to the trough at an terminal block. The grounds originate at a terminal block in the main disconnect where the EGC is also bonded and terminated.
Is there any additional grounding or bonding needed at the trough? We have the neutral and ground separate at the trough.
Is 3/0 AL the correct size?
We were told that we are missing some grounds and bonding at the trough and EGC sizes is not correct?
We have each set of phase conductors terminated with ILSCO terminal blocks.
Not sure what is wrong?
