david
- Pennsylvania
Re: Bonding -Grounding the Neutral
250.28(A) Material. Main bonding jumpers shall be of copper or other corrosion-resistant material. A main bonding jumper shall be a wire, bus, screw, or similar suitable conductor.
Generally the main bonding jumper is the connection between the service neutral and the equipment ground at the service. The material allowed to bond the grounded conductor to the equipment ground is listed in 250.28(A)
Notice though in 250.24 specifically identifies the bonding jumpers listed in 250.28(A) that are allowed to be used to bond buses together if the grounding electrode conductor and the grounded conductor are separated onto two different bus-bars The bonding screw is not allowed in this application
So again I am saying you are not allowed to attach the grounding electrode conductor to a lug unless there is a main bonding jumper the bonds that lug or additional bus directly to the (Neutral Bus)
