tommyh21271
If your supposed to bond to a water line that is metallic & runs at least 10' from the building (underground), is it Bonding or Grounding? And Are we grounding/bonding the conductors/ Apliances, or the water line? And if its the "electrical system", is a Grounding Rod needed? What about Gas lines (fire hazard)? Should they be Grounded/Boned as well? I know when I worked in the petroleum distribution part of things the underground bulk tanks were required to be grounded, or was that due to cathodic protection only?
